I'm not trying to 'make the screen of the Razr
seem better', that's just how it appears to
me. My opinion counts just as much as yours and frankly, if I'm buying the device, a whole lot more than yours. To tell me that it's just 'dumb' to say what I did is frankly 'just plain dumb'.
I was fair in not hiding the fact that the Samoled screens are over-saturated, they are. I said that. But there's no question the blacks on the Razr are far better. So it depends if you appreciate a higher contrast ratio with somewhat hyped colors more than a higher resolution and more accurate colors.
I will take you back several years to a test done with two Panasonic plasma TVs. It was found that most people appreciated the higher contrast ratio of the lower rez TV more than the higher resolution of the other TV (it was comparing a higher contrast 720p display to a 1080p display with lower contrast). The higher contrast ratio of the lower rez display was often interpreted as higher resolution even though it wasn't. This is often how the eye interprets an image. A higher contrast image is often seen as more detailed.
Like it or not, it is what it is. Again, both are fabulous displays IMO and it just depends which aspect of picture quality you appreciate more. There is no right or wrong, and certainly no 'dumb'.
