I think that novox77's explanation makes sense.
I have trouble accepting explanations of differences based on sensors alone.
The LTEvo has a larger aperture, it will present more light to its sensor.
There needs to be two sets of comparisons - one for everything on auto for those that will shoot that way, and one tweaked individually for each shot for those of us who shoot that way.
Then there needs to be separate assessments for the Exynos and S4 versions of the SGS3 because it doesn't have an independent Image Chip with its own image signal processing (ISP). The SGS3 makes calls to the main processor for ISP, and the results of using different processors will vary. This was a key point of Image Sense - getting consistent results regardless of a Tegra 3 or an S4 being used.
Cameras are systems.
I am not satisfied by a few shots and then explanations of differences boiled down to one component in the system when the components of each vary every step of the way.
Perhaps the SGS3 is better. From the comparisons and theories so far, I don't know that yet.
