complete noob needs help!!!
patch321
ok i'm totally new to all this stuff. i have accidentally updated my brand new hero so i am unable to root. i hear there's a way to go back a build so that i can root. i need step by step instructions (tell me like i 'm an idiot) on how to do this. i would really appreciate it guys!!! :(
If you read the guide on how to root 2.1, you will see right up top it says:
If you installed the OTA Update you MUST run the original 2.1 RUU. After you do that, apparently you can root again.
I suggest reading..........
Also be aware that apparently they put the update (.6) in the current downloadable file from Sprint so you will have to get a previous copy of the .5 file. I believe that there is a link to it in that same thread.
Good Luck!
