Root Confused...Help with ClockWorkMod Recovery
pookieguy
Hello all,
I'm a bit confused here as to how to perform a full back. My phone is rooted. I believe I used SuperOneClick or something like that and it did succesfully root the phone and all is fine. However, I see some guides that have many other options on the recovery menu. Mine only shows the option to Wipe Data. ??
I use ROM Toolbox and boot into recovery but don't see all other other options. I have researched a little and it looks like I have to have ClockWorkMod and ROM Manager installed. I installed ROM Manager and now it tells me I need to flash ClockWorkMod. ??
Everything I find on installing this is a guide to ROOT your phone and that's part of the process. I'm confused because my phone is already rooted. I just don't have all this other options and wondering if someone can please help me figure this out?
Thank you much,
--mike
In clockworkmod choose backup and restore
Verify you are in clockwork not 3e recovery
It sounds like you dont have clockwork installed ...you can use rom manager to do so
Ok i am having my own problems how do i get it out of 3e recovery. I am stuck in i guess.
Madmax42
Ok fixed it.
