I have honestly tried every possible thing I can find to root this phone but i keep getting this stupid *file exists* problem everytime
Root For LG Connect
Press any key to continue . . .
* daemon not running. starting it now *
* daemon started successfully *
Phone Found.
link failed File exists
Restarting the phone
Waiting for the phone to restart
Pushing root exploit
cannot create /data/local.prop: permission denied
Exploit pushed
Installing SuperUser
remount failed: Operation not permitted
rm failed for /system/etc/install-recovery.sh, Read-only file system
rm failed for /system/recovery-from-boot.p, Read-only file system
failed to copy 'Files\su' to '/system/bin/su': Read-only file system
Unable to chmod /system/bin/su: No such file or directory
link failed Read-only file system
failed to copy 'Files\busybox' to '/system/xbin/busybox': Read-only file system
Unable to chmod /system/xbin/busybox: Read-only file system
--install: applet not found
failed to copy 'Files\Superuser.apk' to '/system/app/Superuser.apk': Read-only f
ile system
Finishing Up
rm failed for /data/local.prop, No such file or directory
rm failed for /data/gpscfg/gps_env.conf, Permission denied
Unable to chmod /data/: Operation not permitted
LG Connect Rooted!
Hit Enter key to Return to Option Menu
I have SW Version MS840ZVA which i changed to MS840ZV9
then MS840VV3 I tryed almost 30 times on each of these firmwares
Then I used the LG Connect Support Tool to change the firmware which leaves me with MS840ZVA which still cant be ******* rooted
This is a new phone I got after my last connect's battery overheated and couldn't work
its getting frustrating because my last connect rooted many times with no problems....
Root For LG Connect
Phone Found.
Exploit pushed
ile system
Finishing Up
LG Connect Rooted!
Same happened to me after flashing and attempting to root VV4. Perhaps a sticky or updating the firmware OP would help, sammyz?
