Help Connect Nexus to Computer, as a Drive Letter?
I have utilities that I like to use to backup my phone, but none of the will work the way the Nexus shows up on a Windows 7 Machine.
How can I just get the internal storage to show up as a drive letter?
first i would go here and make sure you have the right drivers installed
make sure you camera has USB Debugging on... that guide i believe also tells you to turn it on,.
My drivers seem to work fine. This seems so strange to me that that I can't get a drive letter out of this. Debugging is on.
This is all I get.
cfRe
Is it supposed to get a drive letter? I'm not sure it does that for MTP/PTP devices...
I'm on winXP, and I don't get a drive letter.
This is totally mind boggling to me? I can't setup any utilities to back my phone up now. No programs like the format: "Computer\Galaxy Nexus\Internal Storage", this really sucks.
See sig. It won't be a drive letter, and in my experience, just dragging the folder to your computer fails every single time.
Apparently, this is not an easy fix. So, how about this, as an IT guy, I use utilities to do my file copies, this way if one fails, or I'm promoted for anything, the copy continues with out my intervention.
Now, how is anyone expected to backup their phone if you can't use any of these utilities? Drag an drop, "Manually" is just pathetic.
Is there something out there that I'm not aware off? And yes, I know about TT Backup, but we shouldn't have to root a phone to back it up.
Dropbox and a copy utility on your phone would do what you want and have the advantage of not having to plug in your phone to back-up the files you want.
Well, I guess I'm turning to the cloud. I already use a service similar to Dropbox called, "SugarSync". In my opinion, more features than dropbox. Guess I'll play with it today.
Any real solutions to this yet guys? We are many with the same problem.
I have the same disk configuration as "TheSuperman" user and programs from my computer cannot see the Galaxy nexus drive.
If you see this in the "My Computer" (XP) or "Computer" (Vista or 7) window, then its functioning entirely as intended. It will never appear as a normal flash drive because the Galaxy Nexus uses a different filesystem that isn't compatible with Windows (which is why there is no "USB Mass Storage" mode). As such, if the program needs the drive letter, it won't work.
If you aren't even seeing that, then there are some driver issues.
I don't know, for me, I have no desire to constantly plug and unplug my phone. I wish I had a charging pad so I wouldn't need wires to charge. I think that there are plenty of ways to get content to your PC wirelessly.
As mentioned, there are a number of cloud services like Box, dropbox, and even google drive... and they can even be set up to sync automatically if you don't want to push files around.
Another alternative, and the one I use for direct access, is Airdroid. Assuming you have a WiFi connection, just turn on Airdroid and setup a bookmark for the IP address given and you've got file manager type access on your screen. You can upload and download to your heart's content.
