Well has it been like this since the lollipop update or since rooting?
Ok try booting into "safe mode" (i think you hold in Power and volume down at the same time but you may have to Google it (it should say "safe mode" at the bottom of the screen once it boots).
This disables all downloaded apps so if you don't get the errors in safe mode then it's an app you've installed that's causing it.
Let me know mate![]()
