BoyBrushedRed
I'm trying to view an video on my phone and for some reason the audio and video is out of sync. It's not much a problem at the beginning but more later on, not sure if its cause of the file and its variable bit rate(assuming it is variable) or the actual device. Works fine on my laptop. Dunno how to convert it to a playable file.
Here are the parameters of the file
Video
File type wmv
File size 308mb
Frame width 640
Frame height 480
Data rate 1372 kbps
Total bitrate 1500 kbps
frame rate 29 frames/second
Audio
Bit rate 128 kbps
channels 2 stereo
audio sample rate 44 khz
Video
File type wmv
File size 308mb
Frame width 640
Frame height 480
Data rate 1372 kbps
Audio
Bit rate 128 kbps
channels 2 stereo
