Help Converting DVD's for the Ally
flyinjoe13
I bought a DVD Ripper program from Pavtube to convert some DVD movies for my phone. Since this is the first time I've ever tried this, I wanted to make sure I was using the best settings. For anyone who has ever converted a movie, these are the settings i've been using. Should I change any of them? The one movie I tried had some minor artifacting, but I thought that might be due to the conversion\resizing more than the settings so I wanted to check what others suggest I use.
Video
Codec: h264
Bitrate: 1000
Frame rate: 29.97
Audio
Codec: aac
Sample rate: 32000
Bitrate: 160000
Channels: Stero
Video
Codec: h264
Bitrate: 1000
Frame rate: 29.97
Audio
Codec: aac
Sample rate: 32000
Bitrate: 160000
Channels: Stero
Hey Joe will you PM on where to get the software to do this is
(HEY LOOK ITS MY 200th Post.... YAY!!!)
I am setting new heights in mediocrity:o
i think you ALL need to chill.
i get that flyinjoe wanted to buy a dvd ripper. that's fine. Because sometimes paid apps are better than free apps. yet i understand where darkxson is coming from by not wanting to pay. sometimes not everyone has the money to be able to buy whatever programs they want, but whether you do or do not have the money, you should all respect each other's ideas about buying apps or not.
ANYWAYS.... what i do for converting movies for my ally is keep the res for ally screen and make the file type as .mp4
that seems to work the best for my ally. hope this works, and hope its easy for you to do so.
