i aint buyin it
Froyo?? I'm still trying to get my screens the way I want them![]()
https://supportforums.motorola.com/community/manager/softwareupgrades
Here is the official timeline for releases, though Droidx is stated for later this summer. Some of the Motorola Mods stated September is what they consider late summer. I am sure most of you have seen this already though.
LOL, I know this... Some of the people on the Motorola forums fail to understand that concept though, they think it should be out now.ummmm...September is late summer...which runs until 9/20.
p3droid is pretty well established and no one on that forum is even thinking its a hoax. I also dont think its a hoax. Cant wait to put it on my phone
I see what you're talking about and I went ahead and checked it under Photoshop CS5, as well as looked at other System Information screen shots for the DX.This image is photoshop job, notice how the system information is a lot clearer than the rest of the information.
-Please Read Directions Before Proceeding:
Hello, we know that other sites will post this thread on their site. We respectfully request that you link back here, if you do not honor that request we would ask that you include both posts 1 and 2 and a linkback. BUT PLEASE DO NOT JUST POST LINKS TO DOWNLOADS OR MIRRORS
IMPORTANT:
Step 1:
This is a leaked ota upgrade in the update.zip format. This is not a ROM or a port. This will upgrade both your baseband and your system. You will not need to wipe date.
- The only way this update will work for you is if your phone is back to stock (you MUST be rooted already if you want to be rooted after the upgrade).
- If you have themed your phone you need to convert it back to stock
- If you have removed bloatware you must put it all back.
Step 2
Do you want to be rooted?
1) If no skip to next step.
2) If yes and already rooted skip to next step.
3) If not go here and follow these direction. -----> how to root - thanks to Birdman/rootzwiki
STOP: YOU MUST VERIFY THAT YOUR SU IS LOCATED IN THE XBIN NOT THE BIN
I suggest using Root Explorer as it is the easiest was to do it: Get it in the MarketPlace
open rootexplorer
navigate to the /system/bin folder and hold down the su file, then select move
navigate to the /system/xbin folder and press the menu button (4 squares)
select edit and then paste
Step 3
So have you gotten back to stock:
If Yes proceed to step 3,
if No then proceed below.
If you don't know which files you need or which ones to put back, you can use the sbf to put your phone back in a stock state. You can go here to get details of how to return to stock via sbf file. ------> Droid SBF
After you return your phone to its stock state go to step 3.
Step 4
Now we need to download froyo for the Droid
Place the file you have downloaded on the root of your sdcard.
Step 5
Reboot your phone in recovery mode:
1) Hold down the home button and the power button.
2) When the triangle with the android appears press the search button (far right button)
3) Select apply sdcard:update.zip
4) sit back and wait (5 - 10 minutes)
5) restart your device.
Your phone will now be running 2.2.6 (Froyo Rooted)
Thanks goes out to:
Andrew
Cellzealot
P3droid
Root Thanks:
Birdman
Rootzwiki (Steve)
P3droid
