Help Couple of ?'s
Trevor Philips
So i'm moving from the lg motion to this f6 next month and i just wanted to ask how is the battery life on this phone? phonearena says 18 hours talk time and metros site says 8 hours talk time.... i know both of those numbers are pretty much not accurate but how many hours do you current users have?
Can someone check if the apps ifruit, Sonic Dash, and San Andreas are compatible in the play store with the f6? my Lg motion says "Your device isn't compatible with this version" on all those apps
The battery life if great one problem I have with the phone is space issue there it a semi fix to this, all the apps come back compatible you should be able to run them all, make sure you get a memory card, root phone and apply the sd fix on the page.
Thank you very much, and that's the first thing ill do
