Root Cracked Screen, Need to Unroot
Cjohn8792
So I cracked my screen and just need to know how to go back to the stock rom and unroot so if Verizon agreed to replace the phone they won't know I tried to mess with it root-wise. If anyone has done this before please post your experiences. My friend cracked his screen twice and had a rooted phone and had it replaced twice, so I know it can be done. Thanks.
Easiest thing to do is follow the 2 How To:s on this list. One will help you install Stock ROM and has the files you need to install and the other will help you install the stock Recovery and also has the files you will need. It's not too bad. Read the threads through entirely so you see what others ran into - it will save you some time.
I post from my phone so sometimes it's a little difficult to search for the right topic on this huge forum.
FYI, if you cracked your screen, then Asurion shouldn't care that you rooted your phone.
