Get a silicone case and you won't see it anymore!![]()
thats like the second most annoying thing!!!! I HAVE A CASE, but i took it off cause i was using the camera and i have to take the back off.....
i dont like the silicone ones as they are tick and stick inside jeans, anyone on here know of a good plastic hard case? or would it be better to change the top housing?
Had a gel case since day 1. Very snug, not sticky in the pocket, and looks like it's part of the phone!
Know what you mean about them sticking in pockets but the silicone case I've got has a different kind of back that makes it slide in and out of pockets really easily. Have a look at it here
NEW GRAY FLEXISHIELD GEL CASE COVER FOR HTC DESIRE UK on eBay (end time 18-Nov-10 00:52:51 GMT)
The sides are still nice and grippy so it feels safe in your hands. It also protects the camera as its slightly raised off any surface.
Can not rate this highly enough!
I use the case so I don't have to worry about scratching the sides and back when I place it on a desk. Drop protections is a secondary concern - I make sure I got a good grip on it!
Never used a screen protector. The screen is very resistant to scratches as long as you don't do something stupid like put it in your pocket with coins and keys.
Yeah. Scratches it can deal with.....it's the 4 foot drops onto concrete that cause problems, and a screen protector is not much help there![]()
Yeh dont I know it ..Why is it a phone always drops screen down and lands on something hard..
dropped mine while on the bus on the way out for a pint or 5 ..Shattered the screen. Ended up downing more than 5 pints afterwards to drown my sorrows.
Got it fixed in London in 30 mins..for
