bigbadwulff
Android Expert
It IS possible to create a group of contacts for sending a text to a group. This is a little convoluted so stick with me here.
-Contacts
-menu
-create new group
Now, I'm gonna figure you can get your contacts in that group. After that it is a little tricky. Once it is created, the group is NOT in your contacts(yeah, go figure).
SENDING a message to that group:
-Text icon
-new text message
-hit the symbol on the right side of the "To" field
-Menu
-Display group
-pick the group you want
Now is the tricky part:
-you have to press each one in that group to get them in the To field
-Done
-Send
Took me about an hour to figure that one out! Once you do it, it's pretty easy.
-Contacts
-menu
-create new group
-Text icon
-new text message
-Menu
-Display group
-Done
-Send
