ZandarKoad
So I've got this LG Optimus V, works great, I've got a widget that lets me turn on and off the Wifi Hotspot functionality. I've tried to use a wireless bridge to turn that Wifi connection into a WIRED connection, to no avail. (I tried the Netgear WNCE2001.) Like the title says, I NEED a WIRED INTERNET PORT that is totally mobile that will work wherever I can pick up 3G. I can explain why, but it really doesn't matter for the sake of this thread. Does anyone know if there is a device that will change the phone's broadcasted Wifi signal into a wired signal?
Alternatively, there may be some funky USB to Ethernet cable conversions that might do the same thing, without having to go through the wifi widget...
Assume I've got an infinite budget, and suggest any crazy zany idea you can think of. It doesn't even need to be using the LG Optimus V. It could use another phone, etc.
Oh, I see. The free version limits secure sites. I can't find the pay version on the Android Store...
With a MiFi connection, you would be able to use your OV for voice calls simultaneously while having an active Internet connection. With just the OV, you cannot talk and use 3G at the same time. The costs could be written off as business expenses anyway. Something to consider... best to you and your newborn.
