Distroid
I've done this before, but I've been out of the Android Dev loop for a while. Trying to get back into it.
I found the xda post about creating custom bootscreens that i had followed before.[HOW TO] Make your own bootscreen and create signed zip - xda-developers today I did the same thing and even followed the advice posted by phaelox in post #4 because i remember doing that before.
Stats: htc sprint hero, rooted, running fresh-hero-2.4.0
What i've done: followed tutorial on creating gifs, compiled into .zip using 7zip, signed apk using signapk, copied signed zip to root of SD, flashed zip using recovery-ra-heroc-v1.5.2.img (flash successful), rebooted
Symptoms: at boot shows the HTC logo, then blank screen for remainder of boot. small vibration towards the end, then Fresh ROM loads just fine. everything else works.
Other (hopefully) helpful facts: I've uploaded my signed zip so someone can take a look at it ( maybe try it out ), when i use ES File Explorer the 3 gifs and audio play just fine, so i'm thinking the issue might be the .xml file.
Any help would be greatly appreciated. Ty
-DistroiD
-DistroiD
