I have searched all night and can't find anything that will direct me to an internet connection with cricket.
I have the phone unlocked with a good prl. I can make voice calls. I have been into epst so many times I am about to puke. Nothing seems to work. Please help.
Anyways hope that helps. If not send me a message and I will be glad to help you.
For internet to work you will need to set your proxy settings. If you don't have access to the proxy settings you can use anycut to create the correct shortcut (Make sure to choose Activity then Proxy settings). Then set the proxy address to wap.mycricket.com and port 8080. Now this will only make it so your browser works, you still wont be able to use apps online as Cricket only uses simple IP. To get apps to work you need to do the broadband work around. I just set mine up yesterday and it does kick ass. All apps working with super fast internet. Its like having wifi without using wifi and I still pay less then a Verizon account.Anyways hope that helps. If not send me a message and I will be glad to help you.
So would I still need crickets' wap for my browser? If I can get away with the broadband workaround and not have to have wap internet that would offset my costs of the broadband.
Nope!!! I haven't changed my account yet to take data off, but the way I programmed my phone its not needed. I was in the middle of my bill cycle so I am waiting till my next bill to remove data from my plan. Plus right now its only $35 a month for broadband if you have a phone with them, so that will also help offset the cost. Its still cheaper then a comparable Verizon plan too and its fast, I love being able to use Pandora in my car! no more annoying commercials or talk shows hehe. I just got done documenting my phone programming so if you do decide to go with it let me know and I can send you the exact programming to get the broadband to work.![]()
Well thank you for the info and help. With root right around the corner **knocks on wood...I think I will just wait until they figure it all out. $35 for internet on my phone isn't worth it to me. Thank you very much though. I may cave in eventually.
Someone else here has this working, and as far as I know hasn't gone through the level of money-saving awesomeness that you have.
CRICKET PST Settings Thread! by Ryan Mogul - xda-developers
A fellow Eris forum user, I had a conversation with in a thread a while ago, and it seemed that everything except MMS worked just fine for him.
I'm about to buy an Eris and put it on Cricket for my girlfriend. Any other advice besides what you've posted here, that is good to look out for?
http://androidforums.com/htc-droid-eris/40266-eris-cricket-wireless.html?highlight=cricket
I'm also interested in the broadband workaround, but have a feeling that if the settings for your broadband modem will work simultaneously for your broadband card, and your phone, that anyone could use the same broadband numbers, and it would work just fine.
I might buy a broadband card, and share the info from it with a few friends. I bet it'd work just fine.
Well, then consider this.
For $15/month more, you can just get normal broadband on your phone.
Most Cricket phones can use Mobile web and stuff without the extra $15, but their highest phones charge an extra $15 for the full internet. I'm betting that this service will get you the numbers for $15 instead of $35?
Or by the time your regular cricket plan is -$20, and the broadband is $35, it's exactly the same price per month?
I see ya help a fellow Cricket user good work
For sure, as soon as we gain root within by the time I download the rom I want and have my phone working with mms will be 35mins tops LOL
Based on the fact that, when I set up a Proxy on my computer, I can set it up for wap.mycricket.com:8080 and still load websites,
couldn't you just LEAVE the proxy on when you're on WiFi and have it still work?
If you didn't have mobile broadband yet?
So now I'm confused.
The proxy settings don't get 'read' by wifi?
I thought the proxy settings had to ber changed
