Root CRT animation for Incredible?
VolsMcFalls
Is it possible to use the CRT screen animation for the Incredible? I've seen it around for the Droid X and the Nexus (I think), but haven't seen it for Incredible. Anyone using it?
BTW, I am rooted, but not on a custom ROM.
Download a rom with this built in. Or you may find a flashable mod on xda. My best answers for while not in front of my PC.
Cyanogenmod 7 has it. Check out the how to in the root sticky regarding flashing this rom...if you need a guide.
Use Root Explorer, go to /system/customize/resource. Note the exact name of the bootanimation.zip file. Rename your file IDENTICALLY. Move the stock one out, replace it with your desired boot animation. You can do the same thing with the boot sound (mp3) if you want.
