Hi, i have exactly the same problem on my sons new phone. I have got to step 3 but cannot find the file i have extracted..all that was extracted was something saying odin 3 that would only open with a notepad and sort of settings cog on the icon when i click pda i cant find the file i need ..i dont know if it is something to do with my laptop not having the correct programme to open the pda file or not as i am not very good with stuff like this. Very frustrating as i have just bought him the phone for christmas. Any help would be great thank you
I have tried the suggestions here, but apparently am doing something wrong. Can Someone please walk me through exact step by step instructions on what I need to do. I downloaded Odin, but not really sure what to do with it now, or what it means to open it as administrator, when do I plug my phone into my computer? I am just totally lost. My son is so upset, he is 10 years old and just got this phone last night and can't use it, please someone... HELP!!!
Can these steps be done using another phone and on SD card because I don't have a computer?Download the files i have attached and link.
1. Open Odin as Administrator and extract ZIP
2. Select the PDA checkbox in Odin
3. Click PDA and find the file you have extracted
4. Put your phone in download mode (VOL Down, Home Button & Power button at the same time till it shows a blue screen)
4. See the options and make sure you continue (Should be volume up)
5. Press start in Odin
https://www.androidfilehost.com/?fid=24052804347821707
Ok, so i did exactly what you said, and I pressed start. But then it finishes in like 15 seconds and this screen comes up =(http://prntscr.com/baejt4). Now what?is your phone still locked with this?
So, what happened (probably) is that you didnt turn on builder mode. To do that you need to go to Settings > About > Now tap "build number" times. Then root your phone and the problem should be fixedI have a MetroPCS Galaxy Core Prime (SM-G360T1) and had the problem described in this thread. I was able to use the information posted here to resolve the problem and I would like to thank you guys for that.
My question is in regards to what went wrong. After purchasing the phone, I immediately set out to root it. I used a method that I found online (now can't find where it was) that involved installing a package using ODIN. It worked, verified the phone as rooted. I then set about customizing the phone and in so doing logged into Google. On the next reboot, I got that godforsaken Custom binary blocked by FRP screen.
The phone is now back to normal and no longer rooted. I still want it rooted, but I'm afraid to go down that road again until I have an understanding of what caused the problem and can feel confident that it won't happen again. So, how did I screw it up? What's the right way to do this? There are all sorts of different approaches to this described all over the web and I really don't know what to trust.
I downloaded the Odin and then the link but the link says it is a security risk to open.Download the files i have attached and link.
it keeps saying failis your phone still locked with this?
I've done everything to the point where I have to find the extracted file. I've checked everywhere and cannot find it. I've tried extracting 3x's and it not there.Is there any reason why the AFH download is so slow?
Yes...but it wont work if your phone is locked up in a FRP and wont bootup. disabling it on the web does nothing as your phone is locked up. If you had access to your phone, you can disable it in setting. WTFWhen you turn on for the first time your smartphone you add a google account, which result in you automatically activates FRP. To solve this problem and disable FRP simply googles delete accounts that are stored on your smartphone.
To do this go to:
Settings> Accounts> Google
Then click and delete accounts
The next time you encounter problems related files or other applications or check out the official websites you will find all the information on it including how to disable the FRP for example.
cordially
what happens after you follow the steps from one to fiveI have tried Gxzn method but is still doesnt work
To fix this problem first u have to download SMART SWITCH then install it
Then click emergency software recovery and don't plug your phone to your computer yet then enter your phone model and s/n after it will explains the rest
This work for Samsung grand prime
And I think it should work for other phones
