Help Custom Binary block by FRP lock
Can anyone please help me with Samsung s6 g-920P I bought it yesterday , in the morning I restarted and it's not opening anymore it just apperars "custom binary blocked by FRP lock" WHAT TO DO please Help Me ! I am so sad about this ?
We cant help you as your replying on a forum that is for the Galaxy Core Prime not the S6 sorry
I have samsung j1/6 with model sm-j120f and I cannot connect my phone te pc because i have my phone turned off and cannot turn on my usb debugging. Any help??
First, you need to download Samsung device driver on your pc by clicking on the download link. After complete to the download the file then you need to download the current version stock rom. Then install the ODIN flash tool on your pc. When you download the stock room, then you can find the file in the rar format for that you need to extract the stock rom. You can use the WinRAR or 7Zip tool for extracting the data.
After extracting the file then you need to turn off your Samsung device. After switch off on your then you need to reboot your smartphone in the download mode. You need to press and hold the power key with the volume down and home button at once. After that, you need to wait for the few moments of going into the download mode.
After complete all these posses then you need to attach your device to the pc. Then you need to open the ODIN flash tool. Then you can find a notification that told you that your device is connected to your pc. Now select the AP or PDA option and choose your Samsung device stock rom. Then you need click on the start button. Now, wait for complete the solve custom binary problem. When it complete solving the problem, then your device is restart automatically, and you can see a successful message on the Odin screen.
https://nowadaysmobile.com/custom-binary-blocked-by-frp-lock/
Try holding volume down and power while connecting it to the USB cable. Keep holding the buttons until you see download mode or home, volume down and power while connecting the device to the USB cable.
