kingD313
hello, im so sad, i tried to do this: http://androidforums.com/optimus-m-all-things-root/405821-rom-cyanogenmod-7-lg-optimus-m-ms690.html
and i end up with a brick, after the first reboot the lg screen an the bottom buttons just stay on, doesn't load anything, i need your help, i've tried everything, hard reset wont work, please i need help, it's my first android phone and i don't wanna lose it!!, thank you so much.
Mobile Support
Download LG Mobile Support Tool to PC
You will see the above, click on the download button and download the LG mobile support tool to your computer. If you don't have the usb drivers already loaded on your computer, this tool will read your phone and show which drivers to download. After you've downloaded the tool, run it and then connect your bricked phone to your computer, the tool will read your phone, show you the drivers to download, then you install the drivers, and the tool will check to see if your phone has the latest LG firmware updates; HERE IS WHERE YOU UPDATE YOUR PHONE BY CLICKING THE UPDATE BUTTON and the program will do the rest. (DO NOT DISCONNECT NOR TOUCH YOUR PHONE WHILE THE PROGRAM IS RUNNING. IT WILL TELL YOU WHEN THE UPDATE IS FINISHED)
WARNING!!! LG's update will fix a brick phone by restoring it to LG factory setting and will put 2.2.2 on your phone. You will have to downgrade IF you want to root your droid again; and the instruction are here in the forum. BUT
