Root Custom ROM on LG Shine Plus
Alright, well, I'm considering installing a custom rom on my LG Shine plus, since they both have an Aloha mobo, and similar specs
I know it isn't safe, but I'm extremely curious to find out if it will work
Sure! But mind helping me out with that? i got someone else to "sort of" help me out, but... I tried following this post (his) and it ended up resetting my phone to stock...
http://androidforums.com/getitnowmarketing/221382-custom-recovery-optimus-s-thunderc-sprint.html
You used the wrong thread. Booting stock recovery does a data wipe on your phone. Sorry I was at the park with kids that day and couldn't help much.
Directions to give me what i need are.
You need a rooted phone 1st.
You can either use adb or terminal enumlator app from market.
from adb shell or terminal on phone
Code:
su
cat proc/mtd
verifiy that mtd2 is named recovery.
assuming that recovery is mtd2 on shine plus as it is on ally:
Code:
dd if=/dev/mtd/mtd2 of=/sdcard/recovery-dump-shine.img bs=4096
if its mtd1 or mtd3 then change the dev/mtd/mtd2 part above to the correct partition
you will now see a file called recovery-dump-shine.img on your sdcard.
Please upload that for me as thats all I need and if followed exactly will do nothing but dump a copy of your stock recovery to sdcard and nothing else. Sfter you upload the dump for me I'll build the shine plus a recovery to allow it to have custom roms. If you want a velocity port you will need a custom recovery first to be able to flash it.
Hi guys,
I'm dsixda from xda-developers. I just got an LG Shine Plus as a secondary phone for my vacation.
Here's the recovery.img and boot.img for getitnowmarketing to try:
shine_recovery_boot.zip
Looking forward to a custom recovery image :-)
