Root Custom Roms, saving, themeing and undoing..
baz@gmx.co.uk
I have looked hard to see if this is covered in any other thread - and it may just be my noviceness that has missed something!!
I am running the 2.2 beta (AMAZING!) and have found 3 different themes i like so far. question is - can i "undo" a theme without having to xrecovery the 2.2 rom from start?
And, finally!, will i still be able to receive the .039 update OTA/via wifi once it is released - seeing as my phone is no longer in its original state!?
see New update 2.1.A.0.39 - xda-developers - sounds like multi touch is in touching distance!!!!!!! :D
To answer the first question, no, because changing the framework requires a reboot, and as for the second, you'll need to be running a S.E rom i.e 2.1 to get any updates.
So once i see the update is out there i could just xrec to 2.1 to get it, or probably find a d/l version on here! Thanks again, as ever you rock!!
