- Get rooted.
- Install recovery.
- Install rom manager.
- Install Titanium Backup, open it and press the menu button and make a backup of "all apps + all data".
- Open recovery (DroidX bootstrap), tap the top button, should say you were give supervisor permission, followed by success. Tap the second button to go into recovery. Vol up/down button moves cursor, back button goes to previous screen, camera button does what the cursor is highlighted. Select return and press camera button.
- Open rom manager and create a backup. Call it stock_02-07-2011 (don't use spaces). Make sure the backup completes. Should take a couple minutes. If it reboots right away, it did not work.
When I go to Ti Backup and press menu I dont see make backup of "all apps + all data"
You have to press menu and then batch and there should be an option to do it.
Why do you need to have Ti Backup if ROM Manager has a backup function? Are they different types that are both needed?
Titanium allows you to backup your apps and data only. This way if you flash a new rom you can restore all your apps ans data to your new rom. ROM Manager and Bootstrap allow you to make nandroid backups of your present rom and it complete setup. Two entirely different things. FYI you must have bootstrap to do any kind of rom installing and backup/restore.
Anyway I managed to brick my phone last night trying to install liberty. So, I'd appreciate it if anyone could tell me exactly how they did it or send me a link to a guide
You can't directly name the backup in bootstrap (recovery). You'd have to rename it with an app like root explorer or rom manager. Also rom manager lets you tap on a backup and delete, rename or install it. They both use recovery to backup, but RM gives you a nice interface to do it.
This is what my backups look like in RM:
A backup with recovery will look like a bunch of numbers which is actually the date and time it was backed up, like 20110210064722.
Alright so I put Apex on my phone since I've heard it's a little bit more noob friendly. Anyway, I'm an LP guy and it seems that some of the screen transitions only work for ADW, is there any way around this or I guess is there any good rom that comes with LP.
It's not a big deal but I'm just curious. Also, it seems syncmypix doesn't work at all with Apex so is there any other app I could use to sync fb photos to contacts?
Also just to clarify, what are some differences between Liberty and Apex? I know Liberty has the toolbox which allows you to put themes and such on without having to use bootstrap but besides that are there any major differences? Once again thanks for all the help.
Them's too many backups. You need a therapist.![]()
