Help Custom Themes?
villa1n
Member
Given that us Galaxy users are RAM strapped just wondering what your personal experiences with custom themes are ....
In particular : GDE
OpenHome
aHome
Interms of LAG being a major issue, and customizability. Watched several youtube vids of demo's but would like to have some first hand, not a G1, or a droids take on it.
I used aHome Lite with the 1.5 firmwares and really liked it; it's not as fussy as the others, gave me extra home screens and customisations, and nothing else, which is exactly what I was looking for. Didn't notice any slowdown at all, apart from it taking a couple of seconds longer to load the Home screens.
On 1.6, aHome Lite isn't available. I've yet to find a suitable replacement so I'm running with stock. Someone here recommended Advanced Launcher, but all I can seem to get that to do is give me an extra column (five rather than four) in the app drawer.
If anyone knows of a free way of getting an extra home screen or two, like Spock I'm all ears.
used to use custom themes for galaxo and galaxorecovery rather than use a home replacement.
for 1.6.2 galaxo though there is no such thing as no one has tweeked them to work yet so im using this wicked app which is beta and free called home++ but its only for 1.6 and above.
Introducing Home++ (Home++ by Intuitit)
be aware that if you use this, the default behaviour of the app draw is to slow load to save on ram. you can change this in the settings
Hit menu key, click more, click extended. Home screen settings are there.
the Homee++ app is cool !! its different from the other apps i ve used bfore !! however it does take some getting used to :)
yeah, tats the best part of the app . . .
btw, i tried finding these to change it, but couldnt !! pls, tell me where exactly its located in settings ????:confused:
i use 91pandahome and it seems to give me the least amount of lag.
i also like 91pandahome's layout and.. accessory i guess, for lack of a better word.
i recommend you at least try it out, you can always delete it you know! ;]
-Davey
at the home screen press menu key and go to preferences>performance and untick Lazy load applications then reboot
Thanks, Rastaman-FB
:o Btw, i got too lazy and didnt read the instructions that popped up when i started it for the first time. Had to later reinstall bcoz of some force closes Then read the pop ups which had very clear instructions .
Damn !! i am getting too lazy :)
Tried Home++ and didn't get on with it. Sluggish, and I wasn't keen on the taskbar replacement.
Tried Advanced Launcher again with the advice above, and, spot on, exactly what I was looking for. Thanks again.
Will try some of these... Sound pretty good, what about battery drain vs stock , any major difference? IE do these engage the sleep bug?
