PlayfulGod
Extreme Android User
This is a alpha build, install at your own risk! I am not responsible if you break your phone!!!
This clockworkmod recovery was built following koush's guide..
This is fully working and has been submitted to koush for official release and be added to ROM Manager.
You will need to install this using the fastboot method:
On windows you should see a cmd prompt window flash up and disappear with a few seconds if install completed. If it just hands there waiting on device you need to check the drivers for your phone and possible reinstall them.
Links:
Official build now available in ROM Manager
A2 Clockworkmod Recovery 4.0.0.1.4 RC1
recovery.img for those who want to attempt to flash it from terminal on the phone.
CricKet A2 Full Restore to Stock
- Boot your phone into fastboot - (VOL- DOWN, POWER, Hold for 10 seconds)
- connect phone to computer via USB
- navigate to the recovery dir you downloaded and unzipped
- Run the install script for your OS (windows, linux, or mac)
Links:
Tho those who tested it installed it with the package for the PC. Its been submitted to koush and he will merge when he gets time so hopefully it will be available thru ROM Manager soon too
