TheForerunner
When it comes to flashing roms, ive done it so many times that i can almost do it without looking at my phone, which means its so easy to sometimes just, skip over a certain step in the process.
I propose to question if not already proposed that CWM update in the future perhaps has the ability to run a batch operation that includes wiping the data/facory reset, wipe cache and dalvik in one simple motion. perhaps even create, or at least offer the option, to automatically create a backup.
i figured someone would have a reasonable... reason for people needing to be able to control what operations get done and why, so i figured a Batch operation would solve that as apposed to a just straight, "select this to wipe all three" you know?.
Seems like it would also make it alot easier to teach new comes who are looking to rom their phones. Isn't it somewhere in the first three steps, after creating a backup usually where someone screws it up? after doing all that, flash Zip and reboot is pretty simple.
Im sure theres some technical issues involved that my brain hasn't been wrapped around yet but, its just something i was thinking about and it doesnt seem that impossible to do. Something that leaves the full ability of control, just like CWM is now, but with the ability to press an, idiot proof button, if you will.
