After reading all of the threads I still can't gather if someone has got CWM to work with the LG L70 ms323 metro PCS phone. If so could you please direct me to the thread.
I also got CWM installed and running and added the Zippy rom to make sure it all works flawlessly.
I thought Zippy was a Kernel?
It is a kernel.
Thanks everyone!
MartyMar, you're saying if I place the recovery.img file in the same folder as the LG Laf Recovery...zip folder after I extract it of course. Then run the .bat file, it will not only unlock the bootloader but also install CWM onto the phone??
I ask because I am have a hard time understanding the Thread about installing CWM 6.x.x.x Located Here
Thanks again.
Thanks everyone!
Thanks again.
My computer would refuse to work before I had even installed the drivers.I cannot get the drivers CT HS Phone General Drivers. I'm running Windows 8. Also after installing the new usb drivers Windows is saying USB device not recognized.
I never could install the CT HS ones, I just set my phone on Charge Only, then On MTP, then when I have fastboot on, I set ADB drivers, so it is odd that you're having that issue..My computer would refuse to work before I had even installed the drivers.
