Root Cwm help
In the stock rom it auto starts the usb connection but with cm6/cm7 the drivers were removed to make the rom smaller. There is a link around here somewhere with the drivers that you install on your computer and it will allow transfers.
Well it doesnt say its a problem with the computer
It says the disk is write protected.
I think I saw a link on a youtube video for the drivers though, didnt know it was going to be an issue.
I hope that is what the issue is though!!
I had the same problem but i took my wife's stock phone and hooked it up and the computer took the drivers and i could transfer.
So can you explain how I use the drivers then???
Like its downloading as a .rar file now.
What do I do after the download?
but also remember all when you flash cm6 or cm7, your sdcard is going to say write protected, easy fix just pull down the notification bar @ the top of your phone and tap usb mode and BAMMMM whoop there it is!!!!;)
