Root CWM touch recovery questions
Jenny89128
Member
Ok I will as soon as I get back home.. Had to step out for a Lil but. But very happy u replied. Thank u so much I will on you as soon as I get home ok. I don't really know if IM downloading the right things or not like I said IM not very today this yet so ur patience will be greatly appreciated :-)
I cant even find the thread that scaryalien reposted for me lol :confused: I promise you guys i am a smart personjust dont know about these things...
well to answer you totlth i first rooted my avid through the metro link here on af. then i installed super user, rom manager busybox oh root checker and titanium backup. i had backed up all my important thing in the vault app prior to root. after that i came in here to the forum and read for about two weeks lol (i was afraid to brick my phone) anyway i found a link in i believe it was dadcups thread for the custom rom "slimstock". so i followed instructions and downloaded it from my computer to my sd card. now i wasnt really to sure how to do that so all i did was download the file and dragged it into my sd card lol sorry sorry sorry i think maybe thats were i went wrong. well then after that i reset and went into recovery mode when i go to install zip i says signiture verification failed. phew!!! k now i dont have access to computer all the time so im mostly doing my homework through my avid. plz plz plz help:o:stupido:
Did you make backup and what rom you try to flash
Jenny, download tolth's touch recovery img using your phone and be sure it's on the root of your sdcard. Also your device must be rooted so you can download a 'terminal emulator' from Google Play. So if you meet the criteria of having your device rooted then.
1. Download CWM Touch recovery.img to your sdcard
2. Download a Terminal Emulator from Google Play
3. Open Terminal Emulator and type su for root privilages.
4. in terminal emulator after su "dd if=/sdcard/6031-touch-recovery.img of=/dev/block/platform/msm_sdcc.1/by-name/recovery" Be sure to use the dd command without the quotes and be sure the '6031-touch-recovery.img ' is the exact same name as the one placed in your sdcard root.
That should be pretty much all you need to do. The touch-recovery img I used in the example was the name of tolth's touch recovery.
Ooohhh lol thanks for clarifying I feel stupid now but I kept seeing that word thrown around and had no clue. So thanks :p
ok so I followed the instructions and downloaded cwmtouchrecovery. To as card and typed in path name n all. My phone did reboot after a few tries, but now IM not sure if I did it correctly. Is there a way to tell if I did? Omg u guys IM so stoked right now lol:D
Turn your phone off. Then hold the power button and volume up button at the same time. Keep holding it until it boots into recovery. If it boots into cwm then you did it correctly.
Ok ill try it now what is the difference between cwm and the regular recovery boot. Is th ere anything special i should look for? See i thought id done it coreectly before but im pretty sure it just went into the regular recovery boot
