Root CWR stuck during restore ?
Buckeye Boy
i had a market issue so i went into CWR and selected to restore to file i backed up just prior to that issue. as it was restoring it appears to be stuck restoring data... -162837367.image. its been hanging on this for about 30 minutes now, what do i do? am i screwed now ?:confused:
reboot the phone, and see if it boots up first,
if it does you are still ok
its possible the phone just froze
i would reboot it (if it does reboot)
try restoring your nandroid one more time, if that doesnt work and your phone still reboots, you probably have a bad nandroid that got corrupt somehow..
Are you on the new CWR that works with CM7? I have noticed that it does not always show that it completes and makes it look like it is stuck on the data, even though it has completed.
Having this same issue, two different files from two separate backups. Did backups before going the update path to .602.
Do you guys mind letting me know what you did to help the OP?
i deleted all of my PM's minus some key PM's i have, so unfortunately i do not have the PM's that have the way we helped him, the only thing i can think of is that you also have a bad nandroid, are you wiping data and cache before you restore a nandroid? its possible the class of the sd card could also play a key role in what is happening to it
