raiderfost
just rooted phone last night and installed. Love the rom so far, phone is much more responsive,but today on 3 seperate occasions the phone will not come out of sleep and i have had to rmove battery to wake it back up. Any ideas?
Do you have any SetCPU profiles? If you set the CPU speed too low while the screen is off, you can have this type of issue "waking" it back up.
Dont even know how to set cpu speed
Honestly, the RC1 is now a month old and I would recommend flashing one of the new nightlies. Found here Index of /cm/nightly/heroc/ Newest ones are found at the bottom, try the 9/13
Nandroid first
Boot into recovery
You don't have to wipe data, just wipe Davlik cache and cache and flash right over the RC1 with a nightly. Everything will be as you left it before flashing.
Then, download oc widget (or setcpu) and set your frequencies. Min 480000, max 710
See if that helps
What do you mean by "flash over" the rc1? Excuse my ignorance
we will see if that helps, installed latest rom but cant find oc widget
Screen on or screen off ?Honestly, the RC1 is now a month old and I would recommend flashing one of the new nightlies. Found here Index of /cm/nightly/heroc/ Newest ones are found at the bottom, try the 9/13
Nandroid first
Boot into recovery
See if that helps
Is it possible for me to get my sprint voicemail app back or something similar?
So to install a nightly,
-boot into recovery
-nandroid backup
-wipe cache
-flash the nightly
is that all?
Actually, since he's having problems, wiping beforehand might be a good idea, otherwise, no need to between any cm6 roms.
