.So far I think so good. I mean battery life has improved. The gingerbread U.I is much clearer I feel compared to before.
One question: Anyone know how to enable the battery indicator so there is a number in the bar?
I have been looking for this myself and I think that it has not been added yet.
You could create your own using UOT Kitchen
Steve
You can just add in a battery indicator and leave the rest unchanged.Re-do the whole thing just for a battery indicator?
The menu's had a big overhaul between build #7 and #11, I hope the status bar tweaks will be in soon and I really really want a Miui style battery bar. ooohooooh ohoh ohh
Sorry.
I find no difference honestly if I don't wipe between flashes once you are into the nightlies. So far so good. I am on build #11 as well. However, do get random reset sometimes which can be slightly annoying but overall amazing port considering that the nexus one still has not received the update yet.
It's not a port. It's built from source. From the ground up
Sorry to be pedantic
