so after I restart my phone....My widgets have a "problem loading widget". running CM6 with nightlies. anyone have a fix for this. Having problems with Overclock widget and Jorte.
I have the 9/1 nightly.
For some reason my LED isn't blinking.
Anyone else?
Have you tried uninstalling and reinstalling? See if that helps, if not you might want to do a complete wipe and reflash a new nightly
I have done full resets and flashing some nightlies over rc1 with no luck.
I have tried this several times and I am still having a problem with OC widget, reddit gold widget, and pure grid calendar widget.
Are your widgets installed on the SD card? If so, they will disappear after reboots on 2.2/Froyo (not a CM6-specific issue).
How about jit? Do you have that enabled? Jit can cause problems with widgets
Any suggestions on a 2.1 that has a working GPS?
There were 2 901's, maybe flash the 902 but also look into LED adjustment in menu, settings. Who knows maybe 903 up now!
Hmm...I flashed DD 2.8 and Google Apps, opened Google Maps, and it located me to the T and the nandroided back to my CM6, but it does not appear to have worked as I see the same behavior.I used Darchdroid 2.8
Am I missing something? I miss my WAZE and Navigation.
by the looks of things i feel like it could be complete anytime. by october is kind of a reasonable guess. i personally havent run into many bugs using RC1 and many of the nightlies. Compared to a lot of the other roms available on xda for the hero, i feel this unskinned 2.2 is just fast and works well.
How can the phone die 0% if it's on the charger the whole time?Couple of things you can do to improve battery life
First, have you tried wiping your battery stats? Charge phone to 100%, boot into recovery and wipe battery stats. Then reboot, and let the phone completely die 0%. Then charge back to 100% (keep phone on charger the whole time).
LOOKS LIKE after the 8/13 or so the LED blinking notifications have been removed.
