MusicJunkie
Android Expert
Anyone running this on their Evo4G? What were the improvements or additions to this ROM over 7.1? Anyone experience issues with this one as well? Thanks!
Have you use this ROM and experienced any problems with it or whatever?When I came off 7.1 I realized 7.2 ran much better, then I smurfed it ran vipermod and dt a2sd with ext. 4 and the latest tiamat gb kernel. I love the way my phone runs. But I put similar set ups on other evos and it doesn't run so well. I love it though try it out.
sent from my evo 4g running a bunch of awesome mods developed by some real sweet devs.
Do you flash 7.2 right over 7.1 without wiping anything? OR, what? lol
It's possible that you can, but it's always best when flashing any new ROM to perform a FULL wipe beforehand.
Ive had a few issues with 7.2 and the newest tiamat sbc kernel. Runs fairly well but im experiencing problems with the actual phone and camera. The phone is laggy and wont let me unlock sometimes when i get a call. My mic also doesnt work sometimes and i have to clear cache and dalvik cache to get it to work again. Ending calls is very difficult sometimes because the END button must be repeatedly tapped. The camera issue is the rom itself i believe. The dock is transparent .. so when i go to adjust the zoom slider it selects the flash option which is right behind the slider toggle.
I saw somewhere that it was like an update so I just wiped cache and dalvik cache. It worked for a few hours then went black and wouldn't do anything, lol. Battery pull and nand back to something else I had saved on my PC.
. Do a FULL wipe and reflash the ROM (if you still want to run 7.2). I know it's a pain to set everything up again but nothing beats a clean install.Case and point. Do a FULL wipe and reflash the ROM (if you still want to run 7.2). I know it's a pain to set everything up again but nothing beats a clean install.
Very true. There wasn't much difference from the two (that I used anyway) except for the lock screen but I'll stick with 7.1 whenever I use Cyanogenmod
The nightlies always ran better for my Hero and EVO. Have you tried the latest 4/8 nightly? Team that build up with the GB Mason kernel and you'll have a nice rom![]()
I've always been afraid of nightly roms so I never flashed them. I'm a little worried about the Mason kernel because it's so new, lol
Are you underclocking your Evo? If so, what's your min. set to?
I am not undervolted ... dont have vipermod installed
)I am overclocked with set CPU
