Root CyanogenMod 9.1-- HELP PLEASE!
n00bk1ng
I have a rooted Samsung Galaxy S2 Skyrocket SGH 1727,
and I just tried to put CyanogenMod 9.1 on my phone using CWM Recovery.
I backed up all my data, not through NANDroid, but through apps. Eg, xml copies of my sms.
I booted into CWM and wiped the cache, dalvik cache, and did a factory reset, then flashed CM, and then GApps.
I've been stuck on the Cyanogenmod bootscreen for a while now, and reflashing won't do anything.
Help?
EDIT:
The reason I didn't post in CM's forums is because, for some reason, they won't let me create an account there or view posts. I was like, dafuq?
Welcome to the forums n00bk1ng. :wavey:
I moved your thread to the All Things Root forum. Did you get this problem fixed?
Thank you, Atma :) I'm new, I apologize. v.v
Sorry for the long reply. I thought no one'd reply. :c
I kinda fixed it. I downloaded Android 4.0.4 for my phone and flashed stock back on it, rooted it, and flashed CWM.
I really want CyanogenMod, though. I don't know what to do though, because obviously, the .zip i have won't work.
I think it's meant for the 1777, I have the 1727.
There's an unnoficial CM rom out for my phone, that's the only one i've found, but I want a daily driver and that won't work for that.
Any ideas, or is there a mistake I've made?
Thanks again :)
