Hi guys! I recently installed reppards cyanogenmod and have come across some problems that someone can hopefully help me fix/if unable, atleast reppard will know about some of the problems people are having (ive been reading around for bugs on cgm and turns out i have almost all) some luck :/ apparently plenty of other peoples om's work just fine with it. Anyways here are the problems im facing.
1.status/notification bar=well basically put, i dont have one for some reason and in a way may be affecting downloads from the web.
2.incoming calls=when receiving an incoming call no menu pops up asking to answer or decline like supposed to. Pretty annoying (outgoing calls seem to work just fine though.)
3.cyanogenmod settings=i tried opening it but it just keeps force closing.
4.camera=when recording theres no audio.
5.android market=i know you can fix the login with gapps but for some reason after signing in after trying to download and install the play market would force close. I fixed this by clearing the data on something. If i figure it out ill post what to clear for people wanting to know.
And thats about it. Ill post more bugs and fixes if i find anymore. also if anyone knows how to fix the problems above # 5 please tell me how to do so.
edit"
6.opera mini- when i open opera mini and open keyboard to do a search, the opera feature bar gets stuck at the mid part of the screen making it hard to view web sites. tried landscape and back...nothing.
7.calls- when i transmit a call the volume is at maximum, in order to drop the volume i must raise it then lower it.
edit"
hope this helps.
I'm gonna make it my signature
