Doc
Android Expert
I did it! I've got slimbean. Now I'll be playing the rest of the night
Very cool, I loved that rom, I was some what of a AOSP freak for awhile, ask Code lol........... congrats I think you will like it.....
Hello everyone, after much googleing and youtube I couldn't seem to find the instructions I needed to install CM 10.1 on my s2. A lot of the stuff I read seemed geared to the Sprint version. Which is virtually the same I suppose. I decided to seek help as I tried installing the official nightlies using the instructions on the official cyanogenmod page but ended up bricking my phone and had to reinstall the stock 4.1.2 JB ROM.
I've never installed custom stuff on my phone before, I'm new to this. As of now I'm on stock 4.1.2 non-rooted. So how do I get CM 10.1 on my phone?
You follow the instructions in that post. you need to flash an ICS modem, and use the correct recovery kernel (usually EL26) And have all the files set to go before flashing that kernel as it will not run JB and is only used for the recovery packaged with it.
Well I bricked my phone again following the instructions on the cyanogenmod page, really unfriendly for someone new at this. Wonder if there are better instructions somewhere else.
What exactly am I suppose to do with the StockCWM-EL26.tar.MD5 file? the only way I can extract it and get the zImage is if I get rid of the MD5 extension at the end.
You dont extract the el26 file. You flash it in with odin then boot into its recovery. You then use that recovery to flash the ROM. You also don't change the name, leave it as it is, including the MD5
When I follow this step:
On the computer, open a terminal and run the following command from the Heimdall directory: heimdall flash --kernel zImage --no-reboot
I get an error say the "zImage" file cant be found. Even after I've put the el26 file in the heimdall directory like the instructions state.
 I am trying it out and messing with the settings just to see how everything works, so far it seems pretty stable, well at least the latest nightly.
Check the one stop shop post that is a sticky. In that you will find a link to the post to fix your MMS, the server settings have to be adjusted to the ones for Boost. 4g speeds do seem affected, but then others have said theirs were okay. For upgrading to the next released build, I usually just boot into recovery and flashed the zip, rebooted, then restored any apps I need to (not system ones or data on user ones unless i needed that data). I believe there is a VVM app you can download on XDA to give you your voicemail app back.
Not sure what you mean by choppy. Are you referring to reduced resolution? Check your settings. I haven't run into that issue.
