GregTard
Finally got them all finished. Hope everyone enjoys.
Dark Android is a very detailed dark theme that comes in three different color themes. Each theme has red, green, or blue accents throughout the system.
Changes In This Version:
The following system apps are themed in this version:
Coming Soon:
If you would like to see Dark Android ported to another ROM, Dark Android Designs gladly accepts requests and I will see if we can do so in a reasonable amount of time.
As always, I am not responsible for anything that happens to your phone and all mods, including this theme and all others, have the possibility of damaging your phone. I will do my best to support my theme and assist with any errors that may be caused by this theme. Please read all instructions and entire thread before installing. Important information can be within the thread in user posts. Please remember that I do this as a hobby after my full time job so please allow adequate time for me to respond to a question or issue.
To install Dark Android, download the theme package of your choice and follow the below instructions:
You should always backup your system before installing any ROM or theme.
There is also a goodies pack that contains lots of icons, wallpapers, LP docks, and alternate fonts. To use the extra content in the goodies pack, download and extract them into a folder on your sdcard.
For more information about how to use Launcher Pro to modify your dock and icons, check out their user guide here. Thi sis the best method to learn to customize it.
Included below are also themed version of Google Voice, Launcher Pro, and Widget Locker skins. To install the themed Google Voice and Launcher Pro, follow the below instructions:
To use the Widget Locker skins, download the zip file and extract it to an empty directory on your computer. Review the ReadMe.txt file in the extracted files for instructions on applying the skin. If you have any issues, please post your question to the thread or PM me. Please do not ask "How do I apply the Widget Locker skin?" before reading the ReadMe.txt in the zip file. I will direct you to read it and then come back and ask a specific question.
Download Links
Dark Android Green for Liberty 1.5
Dark Android Blue for Liberty 1.5
Dark Android Red for Liberty 1.5
Extras
Green Launcher Pro 0.8.3
Blue Launcher Pro 0.8.3
Red Launcher Pro 0.8.3
Green Google Voice 0.4.2.13
Blue Google Voice 0.4.2.13
Red Google Voice 0.4.2.13
Green Widget Locker
Blue Widget Locker
Clear (No Sliders) Widget Locker
Black/White Swype Keyboard
Widget Locker Wallpapers
Dark Android Wallpapers
Goodies Pack
If you like my work and want to help me continue my work... please donate.
- Created a few new icons
- Removed the tinted lockscreen
- Black out market with Dark Android tweaks
- Themed stock Android keyboard
- Some font color changes
- Few other mods and tweaks
- Dark Android Wallpaper Pack (Seperate Download Below)
- Google Search Box
- Contacts
- Dialer
- News Widget
- Settings
- Power Widget
- Browser
- Gallery
- Photo Widgets
- Market (From DarkSlide 4.2 thanks to BBCrackman.)
- Stock Android Keyboard
- MotoTorch Widget
- Ringer Widget
- Google Voice
Coming Soon:
- New Themed Swype Keyboards
- Themed Gingerbread Keyboard (that doesn't replace stock keyboard)
Done, posted installable Gingerbread keyboards here.
- Copy DarkAndroid.zip to your sdcard
- Reboot into Bootstrap Recovery
- Install zip from sdcard
- Choose zip
- Browse and select zip
- Install zip
- When complete, use back button or power button to back up
- Reboot phone
- The goodies pack is not installed. It is extra content that can be applied using the below or other methods.
- The icons can be applied using Launcher Pro, Desktop Visualizer, Folder Organizer, or one of the many other choices for icon customization.
- The docks can be used with Launcher Pro.
- The fonts are in flashable zips so once the individual font zip files are extracted from the goodies pack, they can be flashed.
- Wallpapers are applied the normal way using the gallery selection or other tool.
- Copy zip to your sdcard
- Remove .zip from filename
- Uninstall any existing version
- Install through file manager of your choice
Download Links
Extras
Green Widget Locker
Blue Widget Locker
Goodies Pack
I speak from personal experience.
