GregTard
Dark Android Red for Liberty 1.0
Dark Android Red is a very detailed dark theme with red highlights for Liberty 1.0.
The following system apps are themed in this version:
If you would like to see Dark Android ported to another ROM, I gladly accept requests and I will see if I or someone else can do so in a reasonable amount of time. If you would like to test or help in development, please email me at daDesigns@mpmitchell.com.
As always, I am not responsible for anything that happens to your phone and all mods, including this theme and all others, have the possibility of damaging your phone. I will do my best to support my theme and assist with any errors that may be caused by this theme. Please read all instructions and entire thread before installing. Important information can be within the thread in user posts. Please remember that I do this as a hobby after my full time job so please allow adequate time for me to respond to a question or issue.
To install Dark Android, download the package and follow the below instructions:
You should always backup your system before installing any ROM or theme.
There is also a goodies pack that contains lots of icons, wallpapers, LP docks, and alternate fonts. To use the extra content in the goodies pack, download them into a folder on your sdcard.
For more information about how to use Launcher Pro to modify your dock and icons, check out their user guide here.
Download Links
Extras
Red Themed Launcher Pro 0.8.3
Black/White Swype Keyboard
Goodies Pack
Widget Locker Wallpapers
If you like my work and want to help me continue my work... please donate.
- Google Search Box
- Contacts
- Dialer
- News Widget
- Settings
- Power Widget
- Browser
- Gingerbread Keyboard
- MotoTorch Widget
- Ringer Widget
- Google Voice (Installed to system)
- Copy DarkAndroid.zip to your sdcard
- Reboot into Bootstrap Recovery
- Install zip from sdcard
- Choose zip
- Browse and select zip
- Install zip
- When complete, use back button or power button to back up
- Reboot phone
- The goodies pack should be extracted onto you sdcard
- The icons can be applied using Launcher Pro, Desktop Visualizer, Folder Organizer, or one of the many other choices for icon customization.
- The docks can be used with Launcher Pro.
- The fonts are in flashable zips so once extracted, they can be flashed.
- Of course, the wallpapers are applied the normal way using the gallery selection or other tool.
Download Links
Extras
Goodies Pack
