Root Dark Android Themed LauncherPro 0.8.3
GregTard
Dark Android Themed LauncherPro 0.8.3​
I updated the Launcher Pro version I distribute with my Dark Android theme to the latest version (0.8.3). Instead o fupdating all of my posts, I figured I would create a new thread for it instead of updating the 50 threads I have with it in it. Of course, this will work for anyone who uses Launcher Pro. Uninstall current version and make sure to remove the.zip on the filename before installing.
Now available in blue and red
Enjoy
Download Link
Green Launcher Pro 0.8.3
Blue Launcher Pro 0.8.3
Red Launcher Pro 0.8.3
I updated the Launcher Pro version I distribute with my Dark Android theme to the latest version (0.8.3). Instead o fupdating all of my posts, I figured I would create a new thread for it instead of updating the 50 threads I have with it in it. Of course, this will work for anyone who uses Launcher Pro. Uninstall current version before installing.
Enjoy
Download Link
Launcher Pro 0.8.3
I love the Dark Android Theme for Liberty, ty vm! I have one question, can we uninstall LP in Liberty since it's a part of the Rom and then install this?
Or if there are instructions elsewhere sorry I didn't see them, I must have missed it.
Thanks for all the hard work!
If it is installed to system, you can't uninstall it. You may be able to install this as a different launcher. If not, let me know and I will put it in an update.zip so you can flash it.
thank you so much! i've been wanting to update my modded launcher pro but just didn't want to have to reskin, haha.
