mecampo
i did not partition my sd card though i move apps to sd using the manage apps under sytem, where do my apps go then?
btw i run a2sd sysinfo and saw the apps mounted individually as /dev/block/dm-# (# being 0-8 only have 8 moved so far)
i dont see them in .android_secure either, does it still go to the sd card?
im using koni elite series III with dark tremor.
please advise.
thanks
please advise.
thanks
