Root Darkness 2.5 Theme
TripsYou
I'm wanting to put this theme on my phone: [THEME] Darknessv2.5 :: Cog 3.0 Update! :: Multi-ROM Support [2010.01.13] - xda-developers
I am running Cognition 3.04. It says on the post that you should disable lagfix for best results? How do I go about doing that?
Is it ok that I'm running 3.04 and not 3.0 or 3.01 to install this?
Also, do I just drop the file onto my SD card and then go into clockwork and choose "choose from zip" and just install it like that. Is that correct?:confused:
If you know of any other themes that are nice let me know!:D
