darkcyber
Android Expert
Aright, I have Apex 1.3.1 installed and running smooth and got it all backed up now. I want to try DarkSlide 4.2, but after looking at the instructions I had a question. Here is a list of the instructions:
Install:
Bootstrap recovery
Mount System
Wipe data/factory reset (if all ready on DarkSlide there is not a need to do this step)
Install from zip
choose zip
choose DarkSlide
Install
Reboot
My question, on installing this ROM it says to 'Mount System'. Is there anymore danger to having to 'Mount System' while installing a new ROM?
I have found that after rebooting with Bootstrap recovery, but does that do anything any different than like installing Apex since you are having to Mount the System. What does mount the system do?
Install:
Bootstrap recovery
Mount System
Install from zip
choose zip
choose DarkSlide
Install
Reboot
