after further experimentation I see the /data/data is not moved, I am going through the settings on apps and my /data space is shrinking, which should not be happening if /data/data was on sd.
is it also on system/sd?
on further thoughts I am not sure we want that, internal memory will run much faster then even the class 10 sd cards and if we managed to get the phone to basicly run from sd it would run slower.now just a food for thought.. is this possible...???
what if we were 2 set the EXT2 partition up like how its set up for the a2sd but only like how hoark got his ext4, to run the rom, but instead, it would actually run the shabbyrom thru sd-ext2 like a2sd is using the ext2 partition & getting the sd space for the rom..
again is this possible???
sounds like circular logic lmao
seriously though I have to re read that a few times
yes, I open /system/sd and without opening any folders there I get the exact same numbers, 73.53 used and 167.11 freeis it also on system/sd?
also Im not seeing /system/sd/data
I am however seeing app dalvik-cache though.
sounds likely, as if it was moved by a2sd it would just be datayea mines either but i do have a data2, but i think titanium created that folder when i clicked move app data to sd on TB:
system/sd
app
app-private
dalvik-cache
data2
lost+found
I have all those but data2
that instruction is for 2.7.5.3, this is made from version 2.7.5.2-1
the /data/data/ function is not yet available in this version
you should not run system apps from the sd
/data/app and /data/app-private get linked and moved to the sd-ext partition which is mounted as (named) /system/sd
/data/data stays on internal to protect personal data.
/data/dalvik-cache can be moved for further free space although i had stability issues with this
i did move dalvik to /cache using
a2sd cachepart
and that seems ok until i add many apps guess dalvik gets too big for that partition
when he typed system/sd
he was not talking about system apps,
not sure if you thought that.
he was talking about the actual folder
/system/sd
and inside is
/system/sd/app
/system/sd/app-private
etc. I am running with dalvik-cache on sd and it seems ok, but I am using a class 10 card so its pretty quick all things considered.
lmao... i had a rough time typing it so it can not sound ******ed...
long story short. c how hoark has his ex4 rom. well that rom actually running on the sd-ext4 using the sd space.
This will give you a2sd BUT if you perform a factory reset in recovery, you'll need to reformat your ext2 partition with a computer. Clockworkmod formats to ext4 only! Stock kernel and Shabbykernel DO NOT SUPPORT ext4 partitions.
-inigo
his init.d either requires something i'm not aware of or it's broken. i tried scripts named 'script', ##'script', S##'script' and K##'script' and none ran at boot. i had to use the install-recovery.sh to invoke the mount script. i'm trying to make a universal version so install-recovery.sh usesDid ShabbyRC1 init.d require the S## ?
sh /system/etc/init.d/S00mount
adb shell a2sd reinstall
great work! just curious..is there any way to get the CIQ removal to work with this setup? i keep getting the random vibrations and stuck on bootanimation.
Help please dont know where i went wrong or how to fix ...i cant see the a2sd program i could see it before i partitioned my drive however it wasnot reading my ext i still was using the old one from links2sd..so i redid it thru cw but i could bring this up in the emulator..also the extra drive shows up in titanium with a2sd attached to it...i am running the cw V4.0.1.5. mod also if that sheds any light.. [ ]
first i did wipe then used oden to update to latest cvw..i was using Link2d but i think i made a mistake when i loaded the links2sd well i know i did because i didnt reformat my sd (16gb)and the ap2sd would not read it it did however show in my titanium however.. so the next thing i did was download my sd card to my laptop then i went to recovery and wiped my partition and created a new on 5132 and 32swap.. then i did a system mount and data mount..rebooted open up titanium back up and it showed the drive however the numbers look strange system rom ..168mb(32.5free) internal 169mb(119 free) sd card 15.4 (15.3 free) sd crd (a2sd) 503mb(492MB)....now when i first booted it was giving me loops but i went back into recovery did a wipe and phone went to normal.. then i redid the steps as far as mounting and unloading of zip a2sd_prevail_ext4.zip. after that i didnt see the app itself as i had seen previously so i went in my emulator app and ran the check command..and that brings me to "boned" and i dont know about adb never attempted it i dont think..looks like you're boned.
just kidding. but we do need lots of information.
does the phone start or bootloop?
can you connect with adb?
did you uninstall link2sd first? i suppose in theory you could use both but let's get you fixed up first.
step by step, what did you do? meaning from right before this happened until right now. how about now?
did you try the method that involves flashing standard theme and then no-ciq theme? seems most have reported that to work although i don't think it's been tried with this mod yet.
I am running with bloods simple blue nciq and a2sd though I am thinking my battery life has gone to shit with nciq,i did not. i will try that and post the outcome. thanks again
Looks Like Your Having Permission Problems From What Your Log Says....$ export PATH=/data/local/bin:$PATH $acsd check acsd: permission denied $ a2sd check rm: can't remove '/data/dta2sd.lg2': Permission denied cp: can't create '/data/dta2sd.lg2': File exists rm: can't remove '/data/dta2sd.lg1': Permission denied cp: can't create '/data/dta2sd.lg1': File exists rm: can't remove '/data/dta2sd.log': Permission denied [ ] Apps2SD is launching... grep: /init.rc: Permission denied __ _____ | | | | | |__/ | Darktremor Apps2SD 2.7.5.2-1 (2011-01-02) [ ] GetProp Command = /system/bin/toolbox getprop [ ] SetProp Command = /system/bin/toolbox setprop [ ] Mount Point = /system/sd [ ] Creating /cache/dc mkdir: can't create directory '/cache/dc': Permission denied chmod: /cache/dc: Permission denied [ ] Symlinking /cache/dalvik-cache to /data/dalvik-cache rm: can't stat '/cache/dalvik-cache': Permission denied ln: /cache/dalvik-cache: Permission denied [ ] Starting Apps2SD Check Program. grep: /init.rc: Permission denied grep: /init.rc: Permission denied [ ]
