Root DasBamf 2.0.1 - No signal?
Fadelight
Android Expert
I haven't been sleeping much lately, so I'm sure it will end up being something incredibly stupid that I should've been able to figure out on my own... But anyway...
I tried installing DasBamf 2.0.1 this morning and I have no signal with it. The thread about this ROM stated that a Gingerbread radio was required, so I installed that as well... I'm not sure what could be causing this. I switched back to DasBamf remix 1.7 and everything works perfectly on that ROM. Any ideas what I should be looking at?
If you switched back to 1.7 and did not have to reflash the radio then you are using the wrong radio for 2.0. The radio required for 2.0 is the MR2 radio.
Did you flash the GB radio through Rom Manager? It has to be done through BOOTLOADER (not recovery ;)) (Only suggesting this because I tried flashing through RM the first time. :))
Did you flash the GB radio through Rom Manager or recovery? It has to be done through recovery. (Only suggesting this because I tried flashing through RM the first time. :))
I don't usually correct things but this is too important not to fix. Recovery is clockwork recovery. I think you mean it has to be flashed via the bootloader.;)
Yeah, it's probably just an oops but with flashing radios...not too bad of an oops to point out :)
BTW...Fadelight in the house! :D
It's been a while since I've seen you around back in the D1 days...how have you been? Not rockin the X anymore?
UB!! lol I've been around... Just not overly active in posting over the past few months. I moved to Florida in November and the last few months have been crazy with the new job and all. I still have one of my 2 DX's. I talked to Phases about getting my Guide status back, but he doesn't seem interested. :(
Anyway...
Yes, I flashed the radio through the bootloader and it definitely flashed without error. And yes, it still works perfectly on DasBam 1.7, so Yes, I flashed the wrong friggin radio. :o
I grabbed the very first one from this page...
[RADIO] The Obligatory Thunderbolt Radio Thread - xda-developers
And reading through it... I have absolutely NO idea why I thought it was the MR2 radio. You would think I'd have learned already that I shouldn't work on my phone when I am sleep deprived... I had to SBF my DX 16 times because of that.
So I guess it's off to search for the MR2 radio I need so I can try again tonight.
Anyway...
Well its good to see you here! 16 SBF flashes? Damn! :) But I'd be lying if I said most of my tweaking didn't take place in the early AM hours...makes it more difficult when you're nodding off while trying to update your phone.
I think this is what you are looking for http://forum.xda-developers.com/showthread.php?t=1115714
That radio will work on the MR2 Froyo Builds or on any of the GB builds. I'm running that Radio on BAMF PR4 (which is a sense 3.0 GB ROM still kind of in the test phase).
And about the Guide thing, we just added a whole bunch of new Guides and Mods so that's probably why Phases isn't jumping on it right now (just my best guess).
Thanks a ton man! Im going to flash it right now. I am still tired as hell and probably shouldn't be doing this... but I work midnight to 8am and I am sure to be even more tired around 4am when I am normally working from my laptop at work.
LOL...good luck with that ;)
Lol. It flashed great... Now there are a couple of chances for me to have to wipe my phone tonight while figurig out other things. Like why i cant use a different keyboard, for example.
