the router [...]
....won't make an iota of difference as the problem is with the mobile data connection.
the router [...]
I had this problem too. I thought it was apps, 3 factory resets later the same problem kept reappearing even when I only have a few apps installed. Data worked fine on my atrix so what solved the issue was the APN. By default the sammy has a rubbish APN.
add a new APN as follows and problem should be solved:
APN: three.co.uk
MMSC: http://mms.um.three.co.uk:10021/mmsc
MMS Proxy: 217:171:129:2
MMS port: 8799
MCC: 234
MNC: 20
Authentication type: PAP
APN type: Internet + mms
Using the above APN definitely sorted my woes, I now have around 150 apps installed and no data issues...
I had the same problem. Removed "Green Power battery saver". That fixed it.
Hi
I am having problem with my internet (data) connection on my phone.
What's happening is that i start using the internet connection with no problems then at one point i lose data connection - all other serviced work well - sms / calls.
In order to get my data connection back i either have to restart phone or else go to flight mode and off flight mode again.
Is anyone experiencing a similar problem?
Ken
I also found this forum 3 UK Network data hanging - UPDATE THREE ACCEPT ISSUE - Page 7 - xda-developers , more people with the same problems.
I can't get 3G on my newly acquired sgs2 because I can't configure the APN. Every time I try to add a new APN the program stops and I get the following message:
Sorry!
The application settings(processcom.android.settings) has stopped unexpectedly. Please try again
force close
as a result I cannot configure the phone to receive 3G coverage.
Any pointers??!!
Thank you for your reply.
This is my first android phone, I am totally android-illiterate.
How do I re-flash the stock ROM?
Would that wipe out any data on it?
Thanx
I inserted a different SIM into my SGS2 and it worked perfectly I was able to access the APN and configure it to new values. I immediately took that SIM out and re-inserted mine but was quickly disappointed with same old result.
My own SIM also worked with my old htc windows mobile phone. That just added to my confusion!!
It sure looks like it. Although it's not making much sense to me!!Sounds like you need a new SIM then, I'm sure you can get one from your local shop if you explain the situation. Don't let them charge you though - remind them you want it to be able to spend money on THEIR network!![]()
But if that was the case, why would it work with other SIMs? A factory reset would wipe out everything on the phone right?Also try factory-resetting the handset (Settings/Privacy/Factory data reset). It could be nothing more complicated than a corrupt database file causing the APN settings to be lost.
Yes but I was hoping that, as it's a new handset, this wouldn't be to much hassle. It it can be avoided, all the better.![]()
Why are you using Bluetooth to transfer contacts? And one by one at that?
If you can, should try sync your contacts with google from your old phone. Then use gs 2 to sync with google and your contacts will be in your phone.
