Root data connection problems
speedygonzo
Member
I'm running MikG and can't establish a data connection.
I've tried wiping cache and dalvik cache but it didn't work.
I've also tried turning it on and off from the phones wireless and network settings and sadly it didn't work either ...
whats going on??
Thanks in advance.
whats going on??
Thanks in advance.
Is it a secure wireless or insecure? Could need to reboot the router. I know every now and then I have to. Your ISP isn't down are they
Well, its actually my mobile data connection. I have it enabled through sprint and my phone but it won't connect to 3G. I can only get wifi.
Cool! Worked perfectly!
Thanks :D
No problem! :)
Also remember to check the OP when you flash a new rom to see if it supports prl and profile updates. AOSP does not, and the newer sense 3.5 roms don't either.
If you're on one of these roms, just maka a nandroid of your current setup, restore an older sense rom and update both. Then simply restore your setup. Yoy should be good to go. ;)
