data issues using UK GSII in America??
HAHA I meant which version to start with.. but Ill just start with the latest.
My point exactly!
Without a base line, logic dictates, you cannot judge.
If I put two drinks in front of you and ask you to drink one and then ask which of the two you like best... you get my point?
All that flashing one version will tell you is if it is better or worse than your current kernel... not which of the two Siyah versions is best for you.
To do that, you have to flash both and monitor them each for a few days.
kernel wiped, and 4.1.5 installed.
Wifi issue gone.
That tells me that the rooted file has the issue in it. Maybe somebody can address that? It is definitely in the file, since my phone also experienced that issue before Vodafone's update.
Are there only two modems available for North America? I read through all the info and I can only find the two that ironass mentioned above. I'm just looking for further options. :-)
There are loads of modems in the links contained in, "Modem installation - A Dummies Guide", which I referred you to in post #3 of this thread. You will just need to try them to see which is best. The two I mentioned were ones that had received favourable reports from Stateside users.
Gotcha! I didn't know I could try all of them.. Ive stuck with the first one you gave me for now. It seems to work well enough for me for now.
Again, I cant thank you enough for all of your help with this particular issue!!
Many Thanks
Cody
