Hi All,
I'm a newbie to the Z and to this forum, so pardon me for my newbiness.
hehe.
Well let me explain what the problem is.
I am located in Indonesia and have previously used a blackberry bold 9000 (without any 2G or 3G problems before).
With my BB, I know that (As with any other phone) if you go to a basement you normally would lose your phone signal and hence internet connectivity.
But, once we go up to the ground floor again, the phone would automatically reconnect/search its 2G/3G connection.
Problem:
I recently noticed that with the Desire Z (Build number 1.34.707.5 CL2373326 release-keys), with my network settings to "GSM/WCDMA Auto" , once I go up from the basement, I only get my phone functionalities and NO INTERNET/DATA CONNECTIVITIES at all (No E or 3G icon).
Seems to me that it does not automatically reconnect.
I would then have to choose the "Restart" function from the power button or simply untick and tick the "Mobile network" checkbox from the Wireless&Networks options.
Like any other 'Smartphone', I would assume Desire Z would automatically do it right?
Oh yeah, I am still using the same network provider from when I used the BB. So a network provider issue is unlikely.
What I have done since then:
I tried resetting the Z to factory default, but it still doesn't work.
Does anybody have the same problems with me?
Is this a phone/device issue or is this how HTC created the phone to save battery?
THANK YOU VERY MUCH.
hehe.
Problem:
